Discussion topic: Signal dropout
This message was authored by: PDS4
Signal dropout
Sky+ signal on both channels keeps dropping out every few minutes causing pixelation or blank screen.
ive followed all the recommended Sky fixes but no further forward.
Re: Signal dropout
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
