2
This discussion topic has been answered Discussion topic: Saying no card inserted
This message was authored by: NCB7019
Card inserted, but saying no card or should be face up
This message was authored by: Mark39 Answer
Re: Saying no card inserted
Turn the box off at the plug and remove the card. Wipe the gold contacts side with a soft dry cloth. After 4 minutes restart the box and put the card back. If you get the same message, either the card will need to be replaced or the card reader in the box has developed a fault, and the box will need to be replaced.
Avatar for NCB7019
Thanks for your help Mark, I'll try that
