Discussion topic: Satellite signal
This message was authored by: Bp8663
Satellite signal
I have a message on certain channels which says   Your Sky+ HD box isnt getting a satellite  signal
Any advice on getting my missing channels back please
Re: Satellite signal
@Bp8663 the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
