5
This discussion topic has been answered Discussion topic: Satellite signal failure
This message was authored by: Claire353
My brothers sky has lost his Sky satellite signal after bad weather a few days ago. I checked everything they said to do on sky.com. Any advice or do I just need to contact Sky for someone to come out?
Re: Satellite signal failure
@Claire353
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
He will need to employ a local satellite engineer at his own expense to check/realign/repair/replace the dish/LNB if that's the problem.
If he has Sky Protect cover through Domestic and General Insurance he can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
@Claire353
Avatar for Claire353
Daniel0210, thank you for your advise. I will hopefully get this sorted for him.
Sorry just another question, my brother doesn't have internet will that be a problem with Upgrading to sky Q?
@Claire353 unfortunately yes. A minimum broadband speed is required for Sky Q. I believe Sky recommend at least 2Mbps.
Thank you Mark39, that really helps.
