Discussion topic: Satellite Issues
This message was authored by: Kingfisher51
Satellite Issues
I have several channels which are having Satellite Signal issues   ITV 103, Sky Witness107 +207, Sky Showcase 106, Sky Atlantic 108+208, Sky Crime 122+ 222 and Nat Geo 129+229.
Re: Satellite Issues
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • https://192.168.1.254The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream (self-install, no engineer required), if you want to move away from satellite TV and use the Internet
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
