Discussion topic: SKY+HD contract ends soon can I use my box with a freesat user card,without having sky subscription
This message was authored by: robsie
Re: SKY+HD contract ends soon can I use my box with a freesat user card,without having sky subscrip
Record service for Sky plus HD is provided by Sky as essentials package.
Not sure that is correct as confusingly there are two essential packages via Sky, one via Glass and Stream services:
https://www.skygroup.sky/article/sky-launches-essential-tv-bringing-together-sky-netflix-and-discove...
And one via Sky Q (and not Sky+) which gives you access to the free channels only so the likes of Sky Atlantic is not part of it.
https://www.sky.com/help/articles/tv-essentials
It is correct i did it this morning.
Hi Annie.
Contacted Sky this morning Sky plus HD activated to record free chanels, not many channels available but it does what i need thanks for your help.
Robsie
This message was authored by: Gazawest
Hi,my contract has just ended and I'm receiving no signal for my Freesat box. The Sky engineers cut my original Freesat capable to install there own so in answer to you question you're screwed.
@Gazawest unless you had Sky Q (you've posted in the Sky+ forum) the Sky cables can be used for a Freesat box.
If you had Sky Q, the LNB on the arm of your dish would have been changed for a wide band device which isn't compatible with standard Freesat boxes. It would be compatible, however, with a 4K Freesat box. You would need to get the LNB changed for non-4K Freesat boxes.
This message was authored by: Razzio
If anyone wanted to use their satellite equipment to record programmes, I would recommend buying a recordable Freesat box.
Currys sell 4k recordable boxes or there's plenty of second hand ones for sale, including the Humax brand.
If buying second hand, ensure you buy a Freesat box rather than a Freeview box. Freeview boxes work via an aerial, whereas Freesat is through the satellite dish.
@Razzio best in mind that any investment in a Freesat box would have a relatively short lifespan.
I have Sky plus HD with a basic subscription to Sky i can watch and record free to air channels  basicly Freest. If you contact Sky they will arange it for you well worth doing.
