Discussion topic: Remote code luxor tv
This message was authored by: Scott206
Sky+ remote code luxor tv
Re: Remote code luxor tv
I assume you're asking for a code.
Sky no longer provide codes for Sky+ remote so unless someone happens to know it you'll have to go through every code of the hundreds stored in your remote to see if you can find a suitable one. See question 43 of @Annie+UK's FAQ for how: https://annieuk.ddns.net/sky-faq#q02a
FYI the #q02a part of the URL points to Q02 so when you use a link  🙂 below is the quick link 🙂
ttps://annieuk.ddns.net/sky-faq#q43b (note: you can use either a or b at the end either will get you to the question)
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Thanks @Annie+UK.
