Discussion topic: Re: Satellite signal problems
This message was authored by: Lorraine222
I am getting for past few days picture disruption followed by your sky+ hd box  isn't getting a satellite signal message. STV and loads of other sky channels affected so can't watch.  Have tried all troubleshooting and fixes on here and in my sky. Unable to resolve
@Lorraine222
Sky no longer support Sky+ and Sky+HD so won't send an engineer. If you have Sky Protest through Domestic and General Insurance you can call them otherwise you'll need to employ a local satellite engineer at your own expense (or upgrade to Sky Q or change to Glass / Stream).
@Lorraine222  As you've posted you have Sky + your post has been moved froim the Sky Q forum as it is a different system.
Unles you have Sky protect insurance you'll need to employ the services of an independent satellite installer as Sky no longer support Sky+/Sky+HD boxes.
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
So, have you tried replacing the LNB?
