Discussion topic: Re: No signal
This message was authored by: Jackali
Re: No signal
Hi I have the same problem - your Sky+HD box isn't getting asatelite signal.  This has been happening for days now and getting worse daily - what the heck is going on?
Re: No signal
@Jackali
I've moved your post from the thread you posted on where the OP has Sky Q.
Re: No signal
Most likely a fault with your dish setup. Unless you have Sky Protect you''ll need to engage a local satellite installer to take a look.
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
