8
This discussion topic has been answered Discussion topic: Programme synopsis is not available how do I fix it
This message was authored by: Mrs+Bea
I'v read previous comments and tried them all, but I still not resolved
This message was authored by: Annie+UK Answer
Re: Programme synopsis is not available how do I fix it
So you have a hardware fault with Input 2, Check the cable, if you find nothing obvious your have to call someone out to take a look
What are your Signal Strengths/Qualities? Take a look at the link below:
Question Q11 in my Sky Plus F⋅A⋅Q
Avatar for Mrs+Bea
Input 1  All OK
Input 2  no signal
Avatar for Mrs+Bea
Thank you so much for your help, much appreciated. I'll call someone for help
Avatar for Mrs+Bea
Hmmm I've got the same problem signal 2 all blue, seems funny as it's just happened after cancelling sky protct insurance
I doubt Sky would waste resource by sending an engineer out specifically to mess with your dish setup....
You can restore your programme synopsis temporarily by setting Single Feed Mode on in your Sky box settings.
Avatar for Mrs+Bea
Thank you Mark, sorry I was a bit grumpy last night and yes I agree Sky wouldn.t do anything like I sugessted, but I wil try your idea.  thanks again 🙂
No worries,  we all get grumpy some days! 🙂
