Discussion topic: Problem with tv connections from sky + box
This message was authored by: renz
I keep getting a blue screen saying this display does not support HDCP
on the tvs that are connected by the RF out on my sky box
Re: Problem with tv connections from sky + box
Try turning off 'HDMI Control over RF' if it's currently turned on. I think the setting is in the, Picture menu.
Avatar for renz
In the picture settings there is a hdmi control that is off
hdmi resolution output is set to 1080i
rf1 and 2 picture formats are set to 16.9
There should be an option specifically mentioning RF
Does your main tv connect via HDMI?
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Avatar for renz
Defiantly not one mentioning rf
Is there a page 2, try pressing Channel+ on that page
The option might appear when HDMI control is on, it has been a while since I used them pages
Avatar for renz
Yes main tv is connected via hdmi
Turn ON HDMI Control
You may need to trun off the TV and Sky box at the mains, then turn on the Sky box and wait 5 minutes then turn on the main TV to allow the HDMI handshaking to be completed
Avatar for renz
Found it now and turned it off will try it because it doesn't do it instantly
Avatar for renz
Tried all the suggestions and it's still doing it
