Discussion topic: Problem with hard disk drive
This message was authored by: Nige1701
Message posted on 10 Jan 2025 10:04 AM
Hard disk drive fault . No tv listing . Won't record or play shows
Find out more
Message posted on 10 Jan 2025 10:15 AM
Re: Problem with hard disk drive
You could try a full System Reset which might restore normal working, but failing that, you'll need to upgrade either to Sky Q or Sky Stream.
The System Reset option is in the hidden Installer Menu, which you can access by keying Services,0,0,1,Select on your Sky remote.
Message posted on 10 Jan 2025 11:13 AM
OR replace the HDD in the Sky box😉
Although it is not easy to replace HDDs in DRX890/895 boxes😟
