7
Discussion topic: Power consumption of Sky +HD Box
This message was authored by Fairb This message was authored by: Fairb
Hello.
What is the approximate annual cosumption in KWH of a Sky+HD box, assuming that it is not turned off?
This message was authored by Mark39 This message was authored by: Mark39 Answer
Re: Power consumption of Sky +HD Box
Depends. It uses around 30w in standby and a bit more when it's on. And less than 1w overnight if you have Eco mode turned on.
You can do the math.!
This message was authored by Annie+UK This message was authored by: Annie+UK
A Sky+HD box can be in one of the following states:
1. Fully on (Green LED)
2. Standby (Orange LED)
3. Deep standby (Red LED)
Which one are you enquiring about?
Annie  ( Please Note: I am Neurodivergent )
Hardware: Sky+HD Services: Sky Go Extra (via Xbox Series X) • Box sets • Sky Cinema • Sky Sport Complete • Sky Multiscreen • HD Basic
Fairb
Hello Annie.
Assume it is fully on (green LED)
@Fairb wrote:
Hello Annie.
Leaving the box fully on for extended lengths of time is a bad idea as it will shorten the lifespan of the Hard Drive that would be spinning 24/7 and most likely be written to continuously 😞
Not sure what the yearly power consumption is, hopefully someone will have an answer for you
By my calculation it's around 310Kwh per year.
If you want to check: 35÷1000×24×365
Fairb
Thank you Mark.
Assuming an electricity unit rate of 47.5 pence per kwh on the price cap  (most people will be paying a lot more from the price cap increase in October when prices are expected to rise 65%), the current  electricity cost of the sky + Box is £147.
If the price cap does increases are 65%, the annual cost of 310 kwh will be £243 (77,4 pence per unit × 310 kwh).  Sobering.
This message was authored by oj01 This message was authored by: oj01
So, well under a £1 per day.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
On average, new discussions are replied to by our users within 100 minutes
