Discussion topic: Poor picture on common channels when using Sky
This message was authored by: Waterside20
Very poor picture when using Sky on common channels
Re: Poor picture on common channels when using Sky
Can you elaborate on poor? What do you mean by comon channels?
Avatar for Waterside20
Level 2 icon
I can watch BBC1, BBC2 and ITV No problem
When I connect via Sky there is lines across all these channels. Please explain why
I can watch Sky sports no problem
Tune to one of the affected channels and check your signal strength by keying Services > Settings > Signal on your remote. The white part of all four bars should be at least half way across.
Level 2 icon
I'm not Technical and I don't know how to do this ?
Can someone kindly call me and talk me through this ?
Kind regards
Craig
@Waterside20  No one can or will call you on the back of a community post, we are all customers here.
We're customers here and can't therefore call you. No technical expertise needed. just tune tp BBC1 thrn use your remote and key the sequence to check you signal. Press Services, then Settings then Signal.
Then post back and tell us how far across the white part of all 4 bars reaches.
Alternatively you could give Sky a call, but be prepared for them to tell you that you need to upgrade.
Level 2 icon
The white part is fully across on input 1 signal strength and quality ?
Input 2 signal strength and quality has just no white keeps going white then going off
Can a technician call me please
Level 2 icon
I'm not used to this not being able to talk for a service like this
I've told you the white bars are only present on signal 1
Signal 2 there is no white bars ?
Try unscrewing the dish cables in the back of the Sky box and swapping them around
Level 2 icon
Why is no one helping me ?
@Waterside20 we're a customer Community. You're not talking to Sky.
If you want help from Sky you'll have to call them.
From the signal strength you reported, it looks like you have a fault on one of the cables from your satellite dish.
Sky no longer send engineers to customers with Sky+ boxes, unless you have Sky Prptect, so you'll have to get help, at your own expense from a local satellite installer.
Level 2 icon
This is embarrassing to say the least - I need someone technical on the phone please .?
You'll need to call, if you want to speak to Sky.
This forum is primarily customer-to-customer help
Use the following link for contacting Sky: CONTACT
A phone number is given on a link on the page linked to below (click on the "Need more help?" drop down):
There is also Sky's How can we help? page
(make sure the correct country is selected at the bottom of the page)
