5
Discussion topic: Paramount plus on sky HD
This message was authored by CANDYPIG This message was authored by: CANDYPIG
Has anyone else had trouble with paramount plus? I can't find half the programs they advertise ink master etc
help! Thanks
This message was authored by Mark39 This message was authored by: Mark39 Answer
Re: Paramount plus on sky HD
You get a cut-down version of Paramount+ on Sky+, because Sky+ boxes can't handle apps, which is what you need for the full version.
CANDYPIG
Thanks for replying
oh bugger I didn't know that the programs I wanted to see aren't on there
Might be the time to think about switching to Sky Q (no, I'm not on commission or anything)?!
If you go to the movies section on the homepage then you can see the Paramount+ section as there is a decent amount available but it isn't the easiest to find so when you do find it select All Shows from the top menu to see everything that is there.
This message was authored by ednar This message was authored by: ednar
Anyone know why Paramount + added 3 pilots of old shows last week - Frasier. The Good Wife and Blue Bloods.
But only the pilot of each and not even the first normal episodes have been added this week.
Seems rather wasteful given the space limits on Sky + with Paramount to do this when they seemingly cannot give you the rest.
Surely better to add 3 episodes of one each week rather than just 3 random pilots.
On average, new discussions are replied to by our users within 100 minutes
