Discussion topic: Pairing sky plus box
This message was authored by: Ron8
Hello.does anybody  know why I have to keep getting skyplus hd box paired with sky  about every 2 months.
It is the one in my bedroom and used about 3 times a week.i call sky and they do it for me in a  couple of minutes.i once got an automated line which was handy and you just told it what the numbers were of  the box and it paired viewing  card.
Many thanks.
Re: Pairing sky plus box
I don't know why it's happening, but you're not alone - I've seen it reported several times before.
Is the box left in standby (orange LED) when not in use or do you remove the power from the mains (no LED)?
Avatar for Ron8
Yes box left in stand by mode
Can only think it's a hardware issue then
Avatar for Ron8
Ok thankyou for your help.you could well be right as don't have problem  with other dky plus hd box.
