30 Apr 2022 09:23 AM
Does anyone know the four digit code to pair a Sky+ remote with a Bush VL32HDLED tv? Tried various codes found for Bush tv's in general, but none work.
30 Apr 2022 09:26 AM
Apologies should have stated the Sky+ remote is version 10.
30 Apr 2022 10:11 AM
Posted by a Superuser, not a Sky employee. Find out moreHave you tried the codes here?
https://www.sky.com/help/program-your-remote
Try leaving the tv model blank as well as entering the exact model no. If none work, try the Vestel codes as well.
01 May 2022 06:29 AM
Thanks for that, but I have already tried that particular process with no success. Have tried around 60 codes found on various searches.
Appreciate your trying.
02 May 2022 08:39 PM
Posted by a Superuser, not a Sky employee. Find out more@DexterD there may not be any code that works. You can search through all the codes on the chip in the remote to see if there's one that works, if you wish, but it's a tedious process.
If you want to try:
1. Press Select and Red together for several seconds until the LED flashes twice.
2. Press TV then standby alternately (TV, then Standby, TV, then Standby etc) until your TV switches off. If/when it switches off, press Select to store that code.
03 May 2022 12:59 PM
Thanks for that tip, and I have now tried that process, without success. It's as you suggest, there is no code that works. Looks like this model of tv does not have a working code to allow the Sky+ remote to operate all functions. (Buyers of this model of tv, be aware).
03 May 2022 01:55 PM
Posted by a Superuser, not a Sky employee. Find out moreIf you have an earlier version, it's possible that a Rev10 remote might have a suitable code. But unless another Commumity member can confirm, it's a bit of a gamble.
On average, new discussions are replied to by our users within 100 minutes
