Discussion topic: Old Sky Box
This message was authored by: Joel5
Old Sky Box
We have an old sky Box, the model is Sky +. We recently got a new Tv in our bedroom and don't want to pay the Sky Q Multi room subscription, would the box work ok?  Would the free to air channels work?  (could we also take our sky q viewing card and put it in there when we use the box?)
Thank you
Re: Old Sky Box
It will not work as the bit in your dish called the LNB has been changed to accommodate your Sky Q box so the Sky+ one can not be connected to it.
Re: Old Sky Box
A Sky box DOES NOT work on a standard SkyQ satellite dish
Avatar for Joel5
Re: Old Sky Box
We have 2 dishes, one of them is a Sky + one
Re: Old Sky Box
If you connect the Sky+ box to the Sky+ dish, it will be able to reveive the free to air channels.
Re: Old Sky Box
Replace the Sky+ box with a Sky+ HD box ... SD channels are being switched off🤔
