Discussion topic: Not receiving signal
This message was authored by: JGBB
I have a sky dish signal is on and off
Re: Not receiving signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
