Discussion topic: Not receiving all channels
This message was authored by: DaveMorris1952
A fair number of channels are not coming through saying the box is not getting a signal. This is wrong as many are still transmitting as normal.
Re: Not receiving all channels
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
@DaveMorris1952
No signal, or no satellite signal?
If it's no satellite signal I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check/realign/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
@DaveMorris1952 it's not wrong. It's entirely possible to receive some channels but not others be ause of a dish or box fault.
They are all transmitting as normal (otherwise these forums explode) but your particular system cannot receive some of them, typically because of a slight dish misalignment.
This message was authored by: Anythingmore
I have the same problem 405, 407 and 409 indicate no signal received even when other channels are receiving the same live programmes that should be visible  on 409
Assuming that's No Satellite Signal, then the same answer applies. You'd need to employ a local installer to realign your dish.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
