Discussion topic: Not receiving ITV1 HD ON SKY +
This message was authored by: Daffers07
When I try to access ITV 1 HD CHANNEL103 I'm getting a no satellite signal. When looking through system settings signal I'm getting no signal strength or signal quality on input 1 on 103. Went through reset process. Cable check. Still no signal on 103 but now  I'm getting no signal strength or signal quality on input 2. All other channels seem to be working okay!
Re: Not receiving ITV1 HD ON SKY +
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out sky or a 3rd party satellite/aerial company
Note: If you have a communal dish then this is maintained by your landlord/building management and NOT sky
