Discussion topic: Not getting a satellite signal
Message posted on 10 Oct 2026 09:20 PM
We are not getting a satellite signal
Message posted on 10 Oct 2026 09:30 PM - last edited: 10 Oct 2026 09:31 PM
Re: Not getting a satellite signal
@Nici15 if restarting your Sky box by switching off at the plug for 5 minutes doesn't help, the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
