Discussion topic: No tv signal
This message was authored by: nairekrap
No tv signal
I have a red light on the front of my box which has never been there before and I'm not getting any signal for TV at all I'm told to check cables they are all fine my TV was working perfectly when I turned it off last night .
Re: No tv signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am Neurodivergent My Sky FAQs : Go Stream Glass Plus
