Discussion topic: No sky tv
This message was authored by: Mjcrfc
No sky tv
Had 20 power cut
all back on but for last 4 days and saying no satellite
Re: No sky tv
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
