Discussion topic: No sky signal
This message was authored by: Casper+48
No sky signal
Unable to see any programs
Re: No sky signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Re: No sky signal
@Casper+48  Do you mean "No Satellite Signal"
