Discussion topic: No signal
This message was authored by: Roorabbit
No signal
Just got a second hand skyhd box. Not digital. Hooked up to the satellite dish and saying no signal. Any ideas? Says locked on signal in settings. Cant check for a signal status as not an official sky customer. Tried to sign up to sky but cant seem to do this for old analogue sky dish sky hd 🤷‍♀️. Any help gratefully received.
Re: No signal
You do know that you'll not be able to pair a viewing card to the box, thus you'll only be able to view the free channels
Is the dish compatible with the box?
Avatar for Roorabbit
Re: No signal
How would i find out if dish is compatible with dish? Is there any thing i am looking for to find this out? Moved into a property with really unstable copper wifi and digital tv just awful. Thought i could solve problem by going back to a sky+ box and hooked it up to the back of my skybox.
Re: No signal
Also super happy to watch freeview. Can i no longer sign up to a sky package on a sky+ box?
Re: No signal
If the dish was previously used with Sky Q then there is a 90% chance the LNB on the dish arm would need replacing unless it had a Hybrid LNB that has sockets for Sky Q and Sky Plus
Note: Freeview is diffferent from FreeSAT, also the box will not be able to use its hard drive
Re: No signal
I have no idea what an lnb arm is. Does freesat still provide the basic channels?
Re: No signal
There are only 2 parts to a satellite dish
1. The dish that refelcts the signal
2. The arm that holds the LNB where the coax cables plug in to, and the signal is focus to
Freesat channels: https://www.freesat.co.uk/tv-guide?userNid=28801
Re: No signal
channels look more than enough.
thank you for explaining lnb. Still not too sure how i know if i have the right box for the dish. The connectors fitted 🤷‍♀️
is it possible to get  any sky packages with sky+?
Re: No signal
The plugs an sockets for satellite dishes/boxes are standard
Sky no longer provide new subscriptions for Sky Plus, their supported st system is Sky Q but that has not got much more life left in it as everything is going to the Internet (Sky Glass/Sky Stream)
Re: No signal
hi @Roorabbit
Just out of interest,  do you really mean an old analogue sky dish -  a solid round one rather than the oval mesh dishes ?
If so the dish is extremely unlikely to  be pointing at those used by Freesat & SKY
SKY analogue came from Astra 1 at 19.2 E rather than Freesat / SKY diigtal at 28.2 E)
@Annie+UK  has given you all the info about support & SKY Subs etc.
As an aside the LNB stands for Low Noise Block - which I know doesn't mean anything more to customers but as @Annie+UK  mentions it is the electronic bit that collects the signal reflected onto it from the dish
Re: No signal
I do have a mesh dish
Re: No signal
Sorry guys. Not up on my proper lingo of the Sky/sat world. Was loving digital tv when i lived in a field in the middle of nowhere. Now i have moved to 'civilisation' i have had to take some technological steps back and try to reconnect with the analogue world. This seems to be fast becoming obscelete so not sure what to do next 🤷‍♀️
Re: No signal
Thanks @Roorabbit
In which case, as @Annie+UK indicated, it is quite possible/likely that the LNB is one that as been changed to work with SKY Q which is not compatible with a SKY HD box
(although there is a vague possibility that a very few channels could show but on  'wrong' frequencies)
BTW we expect that the majority of customers have no idea what an LNB is
Re: No signal
Does sky q work via an internet connection?
Re: No signal
Sky Q uses both a satellite dish and a broadband connection
