Discussion topic: No signal
This message was authored by: Sheila54
No signal
I have a ' your box is initialising please return a short time to use this feature' I've followed on line guidance and tried to reboot about 3 times and the message is on screen for over an hour. It's a Sky+ box:  We have about 2 inches of snow but it can't be that surely!!!!
Re: No signal
@Sheila54 if snow has settled on the arm of the dish,  that could well be the problem.
Avatar for Sheila54
Re: No signal
Thanks for info
im 88yrs old - I'm just going to have to wait for it to melt 🙂
Re: No signal
@Sheila54 wrote:
Thanks for info
Spray water at the dish using a hose pipe to dislodge the snow
Re: No signal
@Sheila54
We lost satellite signal on our Sky Q due to snow on the dish at about 7.35pm yesterday. Luckily it was back by 9.35. Hope yours is too.
Avatar for Sheila54
Re: No signal
Thank you - I think the weather plus snow was the problem as it's up and running again now. Next door helped me with a long feather duster - lol.  At my age you only have the TV to keep you entertained so when it goes you are stuffed. I cant do the apps that well. But my daughter did get me Netflix which I'm now trying to work out how I get around it.
I'm not bad for my age but its still a bit confusing.  Thank you for your help all.
