Discussion topic: No signal
This message was authored by: Ld31
No signal
Sky HD box says no signal and the website advice isn't working, and no upgrade slots available
Re: No signal
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream (self-install, no engineer required), if you want to move away from satellite TV and use the Internet
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
Re: No signal
@Ld31 you can find Sky's help here. It's working fine: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
An upgrade to Sky Q requires an engineer visit, and with fewer engineers around, there may be a wait.
Sky Stream, dependent on good broadband, is self-installed and doesn't require an engineer visit.
