Discussion topic: No signal
This message was authored by: susan+pavey
No signal
No signal.
Tried all remedies from day and still no signal.
Re: No signal
No Signal or No Satellite Signal?
The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Re: No signal
@susan+pavey  Your duplicate thread you created 5 minutes after this one has been removed as you don;t need to create another thread.
Is the mesage a No signal or No satelliet signal?
 If it's No Satellite signal try the steps here Sky TV no satellite signal | Sky Help | Sky.com | Sky Help | Sky.com
As mentioned in @Annie+UK  Sky no longer support Sky+HD so if it's  dish issue you'll need to employ the services of a local satellite dish installer at your own cost.
