Discussion topic: No signal
Message posted on 10 Oct 2025 01:46 PM
No signal
My sky box is not getting signal for all my sky channels but most of the normal channels are ok. I have followed the onscreen instructions to reset the box and I have also unplugged it too. This has made no difference.
Message posted on 10 Oct 2025 01:51 PM - last edited: 10 Oct 2025 01:52 PM
Re: No signal
No signal or no satellite signal? They are different.
If it is in fact no satellite signal then I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check/realign/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
