Discussion topic: No signal
This message was authored by: Chrissie1950
No signal
My Sky+ box has a green light but on the tv there is a message saying the Sky+HD box isn't getting a satellite signal
Re: No signal
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Re: No signal
@Chrissie1950
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check/realign/repair/replace the dish/LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a previous post on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
