Discussion topic: No signal
This message was authored by: Jaynecraig
No signal
We have no signal. Checked all connections, dish hasn't moved. Turned off and on. Nothing is working
Re: No signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Re: No signal
You can't judge by eye whether or not your dish has moved. You wouldn't spot movement of a few millimetres, which is all that's needed to compromise the signal reaching your Sky box.
