Discussion topic: No signal
This message was authored by: Blyth2
No signal
I have 2 sky outlets. One is fine but the other has no signal. Ive reset the power and checked all the cables but it all seems fine.
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
