Discussion topic: No signal
This message was authored by: Garycalder
No signal
I have no signal on sky hd hdmi1 despite resetting my box
Re: No signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
