Discussion topic: No signal
This message was authored by: Ruth661
No signal
Haven't been able to watch anything for 3 days! Because there is no signal! There nothing else I can add
Re: No signal
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out someone to check your system, another option is to move to Sky Q as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream if you want to move away from satellite TV and use the Internet
Re: No signal
@Ruth661
And if it does say 'no signal' that is a message from your TV so check the cable connections.
▪️I AM NOT A SKY EMPLOYEE ▪️
