Discussion topic: No signal
This message was authored by: Lynda79
No signal
No Signal tried pressing the yellow button to restart box is initialising all the time waited 30 mins still no saying initialising
Re: No signal
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out sky or a 3rd party satellite/aerial company
Note: If you have a communal dish then this is maintained by your landlord/building management and NOT sky
Re: No signal
@Lynda79
”No signal” tends to be a message from your TV.
