19 Feb 2022 04:52 PM
Any Reception issues in Essex and South East?
19 Feb 2022 04:55 PM - last edited: 19 Feb 2022 04:58 PM
Posted by a Superuser, not a Sky employee. Find out moresatellite broadcasts cover the entire UK so regional issues will only be weather related, have the recent storms moved your dish?
19 Feb 2022 04:56 PM - last edited: 19 Feb 2022 05:45 PM
Posted by a Superuser, not a Sky employee. Find out more@Sam+Robert+Bradle If you are using your own dish then it is highly likely the dish has moved ion the high winds.
You should be aware satellite signals cover the whole of the UK and are not confined to small areas, if there was an issue with the satellites the forum would be flooded with 1000's of posts.
Posted by a Superuser, not a Sky employee. Find out moreIt's not a broadcast problem but I'm sure there are reception issues across the country as Eunice will have moved satellite dishes slightly - the dish doesn't need to move much to affect signal reception.
If the weather has calmed down in your area and you're still having problems, best to book an engineer to check your dish alignment.
19 Feb 2022 06:32 PM
it's possible that it has moved very slightly in the storm...but nothing obvious to the eye.
1st thought was a "local" signal problem.
19 Feb 2022 06:40 PM - last edited: 19 Feb 2022 06:41 PM
Posted by a Superuser, not a Sky employee. Find out more@Sam+Robert+Bradle There can never be "local" issues with satellite signals as explained above other than weather related.
20 Feb 2022 07:08 PM
My sky dish has been moved from the storms on Friday and I'm having a nightmare finding someone in sky to help I was connected to India this afternoon for two hours while employees tried to get me to sign up to a new contract no offer of assistance for the dish
20 Feb 2022 07:14 PM
Posted by a Superuser, not a Sky employee. Find out more@Susan+fisher You need to call back and get an engineer booked.
20 Feb 2022 07:20 PM
The only numbers I could find took me through to India with staff not concerned about the service just trying to get me to to sign up for a new contract which number do I call I used the one on the website
20 Feb 2022 07:28 PM - last edited: 20 Feb 2022 07:37 PM
Posted by a Superuser, not a Sky employee. Find out more@Susan+fisher There is no additional number that circumvents the offshore call centres, it is pot luck when you call. As advised call back.
20 Feb 2022 07:32 PM
I don't want to talk to another employee in a call centre they are rubbish and say the same thing constantly and offer no assistance with the dish problem is there a uk number ?
20 Feb 2022 07:35 PM
Posted by a Superuser, not a Sky employee. Find out more@Susan+fisher The number you called IS a UK number as you've already been advised it is pot luck if you get offshore or onshore. So you need to call back.
If you don't want to call Sky then all you have left with is to find a local company to you to do this or your dish will have to remain as it is - unfixed so what happens next is up to you.
20 Feb 2022 07:36 PM
The UK number is the one that goes through to the call centre
You can contact Sky using the number here (See the "Need more help?" dropdown near the bottom of the page)
On average, new discussions are replied to by our users within 100 minutes
