Discussion topic: No signal and initialising
This message was authored by: Reddes
I have 2 skyboxes. The primary one is saying that Your box is still initialising and that I have no signal from the satellite. The other box is working. I've unplugged and rebooted but to no avail.
Re: No signal and initialising
"No Satellite Signal" is an error generated by your Sky box and usually indicates an issue with one or more of the following:
• The Dish is misaligned
The Tuners in the sky box
The input sockets on the Sky box
The plugs on the cables
The cables themselves
The Sockets on the dishes LNB
The dishes LNB has gone faulty for the connections the box is using
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Avatar for Reddes
But I have sky on the second tv
Different cables, different port on the LNB.
Look at the causes I have listed, a lot of them are per box so can affect one box but not the other
