Discussion topic: No satellite signal
This message was authored by: Phyron
No satellite signal
I've had no satellite signal for over 12 hours
Re: No satellite signal
@Phyron try switching off at the plug for at least 4 minites.. if that doesn't resolve it, the cause is most likely a fault with your dish or cables. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
@Phyron
In addition to the above, if you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previously posted on here that they wouldn't send an engineer - but they did offer the customer £ 65 towards arranging one themselves.
