Discussion topic: No satellite signal
Message posted on 05 Apr 2025 04:35 PM
No satellite signal
My sky is saying that my box isn't getting any satellite signal and I can't get to my recordings or demand .
when I go to my recordings it's saying my box is still initialising but it's been doing that since this morning. I have also turned it off on the plug socket and back on again and is still saying the same thing
Message posted on 05 Apr 2025 04:39 PM
Re: No satellite signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Message posted on 05 Apr 2025 04:40 PM
No satellite signal it's almost certainly a dish misalignment. Sky no longer support Sky+ and Sky+HD, but if you have Sky Protect through Domestic and General Insurance you can call them to arrange an engineer, otherwise you'll need to employ a local satellite engineer at your own expense to check it (or contact Sky to upgrade to Sky Q or change to Glass / Stream).
Message posted on 05 Apr 2025 04:42 PM
Turn off your Sky box at the plug and check that the dish connections at the rear of the box are still secure. If there's no change after restarting the box, it looks like there's a problem with your dish setup.
Unfortunately Sky no longer support Sky+ systems (unless you have Sky Protect) so you would need to engage a local satellite engineer to come and take a look. Alternatively, now might be the time to upgrade to Sky Q - any dish faults will be corrected at no additional cost to you as part of the Sky Q installation.
Message posted on 05 Apr 2025 05:17 PM
That's because it can't find a satellite signal.
