Discussion topic: No or Weak Signal
This message was authored by: MES19
No or Weak Signal
No or weak signal. Network connection fine. Box  been 'initialising' for hours. Sky+
Re: No or Weak Signal
Your box can't initialise if it's not receiving a signal from the dish. Call Sky or a local satellite installer to book an engineer to investigate (if you're connected to a communal dish, speak to your building management people).
Avatar for MES19
Level 0 icon
Issue now resolved. Thank you.
