Discussion topic: No TNT sports
This message was authored by: Paddymagill
No TNT sports
When there is bad weather my TNT sports channels do not work but Sky Sports, why is this?
Re: No TNT sports
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Re: No TNT sports
TNT Sports channels are amongst the first affected by a slight dish misalignment. You might find that the SD versions work better when you have bad weather.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
