Discussion topic: No Satellite Signal
This message was authored by: JonathanMSW
No Satellite Signal
On my Sky Signal under Input 1 Network ID / Transport Stream is showing NULL and it is showing No Satellite Signal
Re: No Satellite Signal
@JonathanMSW
Sky no longer send an engineer to Sky+ issues, which they'll tell you if you call them and they’ll advise you to upgrade to Sky Q or change to Sky Glass/Stream. If it’s a dish issue, unless you have cover through Sky Protect (via Domestic and General) you'll need to employ a local satellite engineer at your own expense to check your dish alignment.
