Discussion topic: Multi room
Message posted on 12 Mar 2026 05:40 PM
Multi room
I have 4 boxes covering 6 x t v in my house and they need updating
sky have told me I can have 1 main box and 4 extra boxes but this will not be enough
we will need 6 boxes in total
can this be done ?
Message posted on 12 Mar 2026 05:47 PM
Re: Multi room
can this be done ?
hi @David743
I presume this is if you move to Q
The simple answer is no & even the info you have been given is light on the fine detail :
You can use a maximum of 2 minis at the same time for SKY content - Satellite/Recordings- (only one if you get the non UHD box - Hardware version 32Cxxx) although you can have up to 4 on the account
You may be able to use more at the same time if the first ones in use are only being used for Streaming apps such as Netflix or Disney+
You may, also, wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
Message posted on 12 Mar 2026 06:01 PM
Re: Multi room
Maybe you could move to a business service as it sounds more like the setup for a hotel than a resedentual property
Message posted on 12 Mar 2026 08:41 PM
Re: Multi room
@David743 may I ask why you feel they need updating?
= Sky+ SD boxes x4 (pace bskyb 3100) ===
