Discussion topic: Moving home
Message posted on 28 May 2026 09:35 AM
Moving home
I'm moving home and need my sky moved to my new address
Message posted on 28 May 2026 09:39 AM
Re: Moving home
@Carolmcp first - please confirm you have a Sky+ set top box, where you've posted (not Sky Q or Sky Stream).
Message posted on 02 Jun 2026 03:53 PM
Re: Moving home
Do you have Sky + ? if so and your if your new hosue has a sattelite dish then you should be able to take it with you hwoevr, it cannot be guarnteed that it will work at your new address if it does have a sattelite dish. It is also worth pointing out that Sky + is now a legacy rpoduct and as such many customers have moved over to Sky Q or Sky stream, have you considerered getting Sky stream at your new property ? it works entirely over the interent and I am very happy with it personally. Whatevr option you choose you will need to let Sky know directly taht you are moving home as this is a customer based support forum, please see this link for moving home https://www.sky.com/moving-home
Hope this helps, please let me know if you have any questions and I will be more than happy to assist.
Sky Full Fibre 500mbps
