Discussion topic: Malty room problem
This message was authored by: MarryJane65
Malty room problem
My maltie room box isont working
as a message saying Accessibilty on Sky is permently on the screen& is stuck on settings.
Re: Malty room problem
First thing to try is turning off at the plug for 4 minutes.
hi @MarryJane65
I suspect you have SKY Q - if this is the case:
This message seems to have caused a bit of a quirk so try this:
Press & hold 4 & 6 on the remote to set to Infrared only (so must have line of sight of the box)
Hopefully you can then dismiss the message
Then try re-pairing in bluetooth mode with the box by pressing & holding 1 & 3 together
If this does not work try a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Then try the 1&3 to re-pair & pair with the TV
