Discussion topic: Insert viewing card
This message was authored by: TracyH
Insert viewing card
Sky not working saying insert viewing card. I don't have a viewing card
Re: Insert viewing card
If you have Sky Satellite TV and a subscription you do have a viewing card
See Q37 in my [Sky Plus FAQ]
Avatar for TracyH
Level 0 icon
Went onto my system details & it also says no viewing card
Have you checked the viewing card slot for the presents of the  card?
Avatar for TracyH
Level 0 icon
cant find any card
What's the background to this? Are you new to Sky? Do you have a Sky TV subscription?
Avatar for TracyH
Level 0 icon
Been with sky for years. Nothing changed. Boys went 2 watch football then just came on screen insert viewing card
If the viewing card slot is empty then someone has physically removed your card
Avatar for TracyH
Level 0 icon
No one has removed any card they r 22 & 19 going nuts because they can't watch the football
Have you confirmed this by locating the slot on your box to see if the card is there or not? You might need to clean the contacts on the card with a dry cloth
Have you ordered Sky Q recently (in the past few months) and cancelled the order for any reason?
The Viewing Card is behind a flap.  Have you found the flap and checked behind it?
