Discussion topic: I've just got a blank screen when I switch my Sky+ box on.
This message was authored by SianAS This message was authored by: SianAS
My TV is recognising that my Sky box is on.  I've turning the box off at the socket for a few minutes but that didn't work.  I'm not getting the usual message that the box is initialising either!
Re: I've just got a blank screen when I switch my Sky+ box on.
Have you tried using your TV remote to cycle through the channels ?
This message was authored by Mark39 This message was authored by: Mark39
Turn off both your TV and your Sky box at the plug. You'll need to leave the Sky box off for at least 4 minutes for it to carry out a complete power on reset.
SianAS
Tried both suggestions but it still didn't work
Does the power light on the front panel go green when you turn the box on?
If it does, try disconnecting the cable between your Sky box and your TV, swap the ends over and plug it back in (make sure the Sky box is turned off at the plug when you do it).
On average, new discussions are replied to by our users within 100 minutes
