4
This discussion topic has been answered Discussion topic: I need to connect my Sky + box to my wifi but it has a case-sensitive password. How do I enter this?
This message was authored by: PeterWis
My wifi router has no WPS button, and there is no WPS PIN. My only option is to connect using the wifi password, but this is case-sensitive, and using my remote I only seem, to be able to select uppere case letters. Any suggestions?
This message was authored by: Annie+UK Answer
Re: I need to connect my Sky + box to my wifi but it has a case-sensitive password. How do I enter t
Keep pressing the number associated with the letters it should cycle through uppercase, lowercase, number and symbols IIRC
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for PeterWis
Thanks - for some reason this didn't work previously, but now it has perfectly!
This message was authored by: Chrissies
It's not working with that
Yolu haven't referenced the post you're replying to. What's not working with what?
