Discussion topic: I got no signal
This message was authored by: Naz12
I got no signal
The message on my tv
check the external input or select another input the source button
Re: I got no signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
Re: I got no signal
That means your TV isn't getting a signal from your Sky box.
A couple of things to check:
Is the power LED on your Sky box green?
Is your TV switched to the correct HDMI input?
Is the HDMI cable between your Sky box and your TV securely connected at both ends?
